if yes and it didn't work but the clock works, than replace PN=316239400, Its a power board for the ovenif yes and it didn't work but the clock works, than replace PN=316239400, Its a power board for the oven
You can't post conmments that contain an email address.
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Although
gas range oven may prove useful for cooking and baking, they may fail
to ignite if they aren't properly maintained and set up. Lighting a gas
range often involves simply turning a knob; however, blockages from food
particles and debris caught in the burners, improper burner cap
installation and gas supply are common problems that interfere with your
gas range oven's performance. A few troubleshooting guidelines may
solve these problems safely.
Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
Clean the burners if you have gas but your burners still
won't ignite. To clean the burners, lift the burner caps
Inspect the small vertical holes on the side of your burners
for dirt, food and debris. The gas won't ignite if they are clogged.
Scrape dirt, debris and food from the vertical holes using a pointy
object such as a toothpick or paperclip.
Reinstall the burner caps properly. If they are tilted or
wobbly, the gas may not ignite. Install the caps on the right burners.
Some burners are smaller than others, so match the caps to the
appropriate burners.
5
Move the burner knob to the "Lite" position and wait for the
gas to ignite. If it ignites, rotate the knob to your desired setting.
If it doesn't ignite, contact a qualified appliance technician.
The clock display works on 120 volts but the burners and oven require 240 volts. I would check the breaker or the receptacle to see if they're bad.They may be supplying only 120 volts. One more less common problem could be the terminal block on the range where the power comes in. Very rarely they will melt. BE SURE TO UNPLUG THE RANGE if you have to check the terminal block. Hope this helps.
Usual faults in this order are: Faulty oven element - check element for holes, blow marks etc; Burnt off wiring at the oven element terminals - check terminals; If the oven indicator lights when the oven is turned on it should be the above. If it does not refer below; Electronic clock set to auto. mode instead of manual mode.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
It's a stand alone. Model #PLEF398CCD.
Oven does not work.
