Panasonic PV-GS300 Mini DV Digital Camcorder Logo
Anonymous Posted on Sep 02, 2010
Camera says to push Reset switch. Problem persists after many times resetting switch.
Anonymous
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on Sep 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
19978
Points
168
There are connection issues on your main PCB. We have been successful in solving this issue by repairing multiple connections on the main board and then applying a special antioxidant grease to the connectors. This repair should be done by an experienced technician.
www.austintelstarservices.com
3 Related Answers
A
Anonymous
  • Posted on Jul 01, 2008
SOURCE: PUSH THE RESET SWITCH PROBLEM
same problem....
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Aug 20, 2008
SOURCE: error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Anonymous
  • 4234 Answers
  • Posted on Oct 19, 2009
SOURCE: push the reset switch
The means that the powerup self test is not completing successfully. If there is no error indication in the viewfinder, this unit will need to see a Panasonic servicer for repair.
Dan
13helpful
2answers
Push the reset switch
Dan
1helpful
Dsc p73 wont switch on when in green camera mode. Tone is short, swiches on in photo preview only with normal tone battery is fully charged.
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged.
Please reset the camera by pressing the reset button located near the DC IN jack. if the issue still persists, please power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
3helpful
Lens stuck outside. Sometimes says "access" on lcd.
Try these troubleshooting steps and check if it help to resolve it.
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Press the Menu button on the Camera.
2. Then, select the SETUP menu and select the SETUP 1 option of the Camera.
3. Then, select the Initialize option to OK.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
I have a sony cybershot dsc-f707 Icant zoom in or out only after I take a picture. I also wanted to know if I need to charge the lense to zoom?
Option 1:
Reset the Camera and check if it helps to resolve the issue.(Resetting the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
The RESET button is located inside the battery/ Memory Stick cover. The Camera should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
Option 2:
Use a fully charged Battery in the Camera so that the Zoom function work normally.
1helpful
Sony cyber-shot 7.2-Megapixel Digital Camera pink DSC-W120 lens keeps going in and out it want stay out so its says turn your camera off and on again I keep doing that but its doing the same thing every...
Option 1:
Try Initializing the Camera as follow; (Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
1. Touch the HOME and select the SETTINGS menu in the Camera.
2. Now, please select the MAIN settings menu.
3. Then select the INITIALIZE option under the MAIN Settings 1 menu.
Option 2:
Option 3:
1helpful
Dropped camera dsc-w120.
Option 1:
Press the Home button on the Camera. Then, select the SETTINGS -> MAIN SETTINGs -> MAIN SETTINGS 1 -> INITIALIZE -> OK.
Option 2:
Sony cyber camera
The Camera is displaying the Turn the power Off and On again message when the Lens in the Camera is stuck or when any internal malfunction happened.
To resolve the issue turn the power off and on several times. If the issue persists, try power resetting the Camera. To power reset the Camera, remove the battery from the Camera.
Press and hold the power button on the Camera for 30 seconds.
Remain the camera without power for 60 seconds and re-insert the battery.
Also try resetting the Camera back to factory default. Press the RESET button located at the lower right corner of the control buttons using a sharp pointed object.
If the issue persists, service may be required.
Good Luck
Thanks for using FixYa
2answers
Error message "push the reset switch"
The Panasonic manual for this problem is stupid. It says "Pushing reset button MAY help resolve the problem"...
nothing else-no explanation of possible problem.....worthless.....
3helpful
3answers
hmm...maybe:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
3helpful
2answers
Press the reset switch
Same "Push the reset button problem in panasonic gs 200 camera. i turned it upside down but it didnt worked out. its an expensive camera please please please tel me how to fix "Press the reset switch" problem
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
