blank lines across fax: if you get it when receive its from the sender but if when you send or make a copy you should clean properly the scanner unit with alcohol and cotton, its the trace of corrector liquid
Yes you can stop it printing the report. Use the menu to cruise through the settings for fax. You will find the reports section and recognize that you don't want the memory storage report, so disallow it by pressing th no key.
your ccd is shot... this is the piece of equipment that actually scans the copies.... its the component under the rectangular glass ****.... a tech needs to replace it...
Sounds like you may need to clean the optics. Open up the area where you insert the original to copy, there you will find a small long glass that needs to be cleaned, I would suspect there is white out on this causing you lines or it may just be dirty.
