Question about Jenn-Air JED8430 Electric Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
When the switch control for the double burner is turned to the small burner, the full burner still comes on and only at high. When the large burner is turned on, that too is not adjustable, and remains on high. Is my problem with the burner, or with the switch, or something else?
  • 2 more comments
  • Anonymous May 22, 2008
    I have the same problem. I'm having someone look at it tomorrow.
  • Housewife2 May 25, 2008
    Thanks for the suggestion. By "ignition switch", I'm assuming you mean burner control. The stove is electric and as far as I know does not have an ignition switch.
    If it is the burner control, is it something that just plugs in, or does it require special wiring and an expert technician to install?
  • Jasanirn Aug 02, 2008
    My dual burner for JED8430 stops working after a while, I had replaced the switch as well as the limiter (thermostat). But with the new switch it worked for one time and now the light for the switch comes on but the burner does not come on.
  • Jasanirn Jan 30, 2009
    Dual switch on my JED8430adb stops working after a while. OI have replaced two switches.
It's an ignition switch. don't change the burner cartridge.
Posted on May 22, 2008
    repairclinic.com
6ya staff
SOURCE:
Large right/front burner is out of control. Regardless of the setting, the burner heats very high. In fact, recently, oliver oil in a skillet ignited. Even though the control was set to less than medium,...
The switch for the right front burner is defective and needs to be replaced,its bad as far as internally when turned on no matter what its set it the interal contact is stuck on only high so their is no setting it will work on except high. By replacing the switch it will work on the various settings and not just high.
GENE
Sep 23, 2011 | GE Cooktops
When I use the front right burner on high, it keeps clicking on and off. Both the small and large burner does the same thing.
Sorry to read about your problem, I hope this helps you out.
you have a defective sensor control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
werewr
Dec 23, 2010 | GE 30 in. Profile JP938 Electric Cooktop
My large burner at the front does not work, yet when i replace it with\r\nthe large burner at the back it does not work , yet when you put the front burner at the back it works.
Your front burner is fine. Assuming you have an electric cooktop the problem is in the switch that controls that burner. The infinite control switch. Replace it.
Dec 07, 2010 | Jenn-Air Cooktops
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Burner is on high all the time
Is this an older unit - 5 years or more in use? Sounds like the burner element is shot. Check the Amana web site for a replacement.
Bill B.
San Antonio
May 12, 2009 | Amana Cooktops
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
Electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Apr 06, 2008 | Cooktops
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
591 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
MARLON KELLER
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
