Thomson RCA Bookshelf System with 128 MB MP3 Player, RS2052 Shelf System Logo
Posted on Sep 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
This product has an aux source. I was wondering how to work this
Cool Blue Services
Level 3:
  • Master 560 Answers
  • Posted on Sep 02, 2010
Cool Blue Services
Master
Level 3:
Answers
560
Questions
0
Helped
225074
Points
1573
Aux. Is for a device input that you can add to your system.
You have 2 RCA Phono jacks on the back for plugging in the device.
1helpful
2answers
Can't get headphones to work on this unit
Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
Hi I am having problems with my Panasonic SA-AK200 stereo system when in AUX mode. What happens is when I play through AUX mode The Sound only comes through One speaker usually the right one but when on cd...
Looking at your question, it appears that the problem is not always on the same channel (right/left). This makes me wonder if the problem is the source or the cables you are using. The easy way to test this is to connect everything, check which speaker is not working, then swap the left and right cables at the aux jack. If the same speaker does not work, then it is a problem with the SA-AK200. If the problem switches to the other speaker, the SA-AK200 is not the problem and you should try replacing the cables or suspect the source (whatever you are trying to connect to aux) is at fault. If the SA-AK200 is the problem, I would suspect bad solder connections at the input jacks. Good luck
1helpful
How do I attach an MP3 player to the receiver? I have an Bose Accoustimass 15 attached and am using the AUX but only getting muffled sound from the sub-woofer and none of the speakers are working with this...
Try another source on AUX to prove the AUX works ok with all speakers.
Any iPod, smartphone or MP3 player at its most basic level is just an ordinary analog audio source.
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the iPod manual because they want you to purchase expensive accessories like docking stations. You'll still have to control the music from the portable device. Oh well.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
3helpful
2answers
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Problems with sound from AUX. WHen choosing AUX music starts and then stops after a few seconds. Why ?
What is the source that youhave fed to the AUX. make sure that the source is not stalling the music, or the source button is tripping off. please recheck if the amplifier is working fine otherwise.
Hi, I am trying to get the aux input to work and am wondering which set of rca outputs to use, front, rear, or constant level? I have not been able to find out which one to use from my manual. I have...
There is either a headphone size jack on the back labeled aux or a blue square plug. If it is the headphone jack then you need a 3.5mm to 3.5mm cable. But if I remember right you have the blue plug and need to buy the auxillary adapter. Then you need a 3.5mm to rca cable. The outputs are only outputs not inputs. Turning the Aux on in the menu does bring it under Source now.
1helpful
Aux chord stuck in dash
http://documents.victorytechnologies.com//documents/product/9039.pdf
4helpful
Put in new car battery, now can't get aux to work
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
19helpful
3answers
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Top Thomson Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Mikey
Mikey
Bob Kirkwood
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
