If it was in anything other than clean water, place it into a bowl of clean water, completely submerged, to clean out any remaining pollutants for at least an hour. Then, do the following:
1) pop out the sim tray using a sim key or something no bigger than a small paper clip. Allow any excess water to drain out, turning the phone in all directions.
2) place the phone next to the grate at the base of your refrigerator for at least 48 hours on a towel to absorb any excess moisture.
3) allow to charge and you should be good to go.
Remember-- do not charge or try to use your phone before drying it out. Do not place in rice. The little particles can get into the little openings in your phone and cause damage, particularly in the charging port.
Full article at: http://www.idroppedmyapple.com/articles/i-dropped-my-iphone-in-water/
Useually unrepairable but take the back off then remove battery and sim then use a hair dryer to try and dry out the moisture sometimes it works depends on how much water damage is in the main board
