the start button seems to be too smooth and it won't start anymore. the rest is working wellthe start button seems to be too smooth and it won't start anymore.
AnonymousNov 16, 2008
heating elementheating element
You can't post conmments that contain an email address.
if theres 4 buttons on facia they are from left to right pre wash extra rinse spin cancel and start depending on which button is flashing you may have a problem if the dial is at 12 oclock and the start button is flashing set the dial to any program and the light should stop flashing if it does not you will need a new board for it and it will need resetting with a servis hand set as servis are now no longer you may have a problem... hope this helps
many servis have an induction motor but later models have a brush motor. worn brushes will not cause an earth fault. suspect part of the motor windings are down to earth. also possible you have a leak in the tub or door gasket so that on spin, water is thrown onto an electrical item
heating element
