I have a 42 inch LG SD Plasma TV, basically picture went from crystal clear to fuzzy and now dark. I can still see outlines and shapes but thats it. Even the LG Menuis basically dark as well. Wondering if its a fused or if the TV is just knackered. Its about 5 years old.
we can here the sounds but no picture. we need a code to unlock the picture thing we can here the sounds but no picture. we need a code to unlock the picture thing
You can't post conmments that contain an email address.
This could be the main drive board failed, or the plasma display backplane has a defect. These types of repairs are generaly fairly expensive.
I would be considering to get an estimate just in case it is simple fault. But, if the repair will cost more than a few hundred dollars, I would strongly suggest a new set. Also, servicing an older set is a gamble in case something else will soon fail.
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
If you can see a faint picture with streaking you most likley have a defective Zsus module
Part Number
6871QZH036B
Description
PWB(PCB) ASSEMBLY,DI
List
$226.14
Please rate my info
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
