Try to reset it ..by unplugging the oven ..and put it back after 30 minutes or so ...it may be a function set ..and remained there ...if the fan is not stopping ..than it is probably a wire that has a bad connection and feed s it with electricity when it not supposed to...probably the isolation went off from the heat ...and in this case you need to call for a specialized hand to see the short and fix it ..
