It is called convergence problem. Model indicated uses a single convergence chip for this. I will attach photo of the part; part on EBAY is well under 20 dollars.
Part is a STK-393-110.
The good news is I have start to finish, step by step instructions for the do it yourself person for this repair.
If you want the instructions which tell everything you will need and how to do the repair rate this solution as very helpful and let me know how to get them to you.
SD TECH
Testimonial: "excellent"
Yes very common. the convergince is off Meanning that the three colors dont alline proper. may be that it just needs to teak the converg settings or the convergince board is bad. worst case convergince ic'c are defective. bench test and shop fees will run $170.00-$380.00 +/- if you want get it checked out but you can get a plasma for twice the money.dont buy dlp lamps dont last. good luck!
