Go to your messaging place and go to settings. When you are there, it should be number 7 and you can type in whatever you want and it should so up everytime you have a new message or reply to one. So there you go.
How to make my text message have my own signature whenever i sent it to others ? I'm using sony ericsson W890i . I find for a long time but still couldn't find it . As all the army phone's can do but why can't mine ?
Well most phone comes with an option known as "templates"
look in your message setting or options during composition of messages.
you should find something like "insert templates" if you have not set it up do so in your message settings.
though with this only option you would have to insert in but not to write it............
it is convenient but must select option to insert it.............some phones do display it as "quick notes"
good luck
Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
How do you set a signature for text messages on the LG G2?
