SOURCE: delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
SOURCE: where can I find a K-cup Portion Pack holder and
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
SOURCE: brewer does not brew every time
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
SOURCE: MY KEURIG B70 IS CONTINUALLY PROMPTING TO "PRIME"
Hi, Lauren..
You can download another manual here.
Cleaning any coffee brewer is essentially the same. The easiest way is to brew one or more pots of white vinegar... it'll stink up your kitchen, but it's effective at removing build-ups and mineral deposits. Be sure to follow up these "vinegar brews" with several "plain water brews" to remove all the vinegar!
Also, if your water reservoir isn't clean (open the lid & do a finger swipe), you can use a brush to clean it or - what I do - wad up a paper towel or two, attach it to the end of a long-handled wooden spoon, and use that to get down deep into the reservoir & scrub it as much as you can before the vinegar treatment.
Alternatively, you can spend $3 or $4 for packaged cleaning compounds at stores like Williams & Sonoma.
If your brewer is not brewing the full amount selected, it may be caused by the following:
?· The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
?· The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
?· The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this helpful tip
Then try also this useful tip
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
Before trying to descale, take a paper clip, bend is straight for about 1" and run it into the pins at the K-cup holder...
Check out this tip about how to
descale your Keurig coffee brewer
How
to Descale your Keurig Coffee Brewer
heatman101
