Question about HP PSC 2175 All-In-One InkJet Printer
Constant whirring noise and won't print
When I turn on the printer it starts making a loud whirring sound that comes from the right back corner. It sounds like something is spinning and hitting up against an object multiple times (roughly 3 times in quick succession). When I open it I can't see anything to account for the noise. There are no error messages. It sounds like it is trying to print.
  • Alice in PDX May 09, 2008
    It won't print anymore.
  • vdyatlov May 26, 2008
    I have the same problem, during anitialize noise from skaner catriage.
    Checked the riboon cable - OK
    Looking like sensor problem - not stop the catriage.
    Help, pls!
Try to clean up the lamp and cover inside(white area).
Posted on Jun 09, 2008
I do have the same problem with my psc-2175. I opened it and recognized that the problem is with the scanner unit. There is a sonsor in this unit which locates the scanner lamp at the beginning point when you turn it on. When this sensor fail to function, the electric motor, which moves the scanner lamp will not recognize where to stop and it works without any stop. So it pulls lamp unit into its borders and make the noise you hear.
I wanted to let it repaired, but I found out that it will be very expensive and it is better to buy a new set. I have bought it in Iran 1600000Rls (170$), and the repair cost is almost 750000Rls (78$).
If you find another solution please let me know, my email is: decoder84@yahoo.com and my name is Soroush Asarzadeh.
Posted on Jun 08, 2008
6ya staff
SOURCE:
HP 2410 Photosmart All in One Printer
the clicking sound is coming most likely from the printhead carriage, if you open the printer so you can see the cartridges, is the carriage stuck? trying to move to a direction and makeing the sound?
Sep 30, 2008 | HP PSC 2210 All-In-One InkJet Printer
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
Starter making whirring noise.
When you say it won't start you mean it won't crank, right ?
If you have a duralast starter from auto zone, that may be the problem.
Aftermarket brand starters and alternators can be lemons sometimes.
A mechanic would check for voltage at the starter with the key in the on and start positions. Also check the ground connections.
Its possible the starter is not getting full battery voltage for some reason.
Jul 31, 2012 | Jeep Cars & Trucks
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
A constant whizzing
that whining noise is definately your power steering pump. the earlier models eg 2001-2003 just have noisy ones. so they say, if that noise become really excessive; its an early warning that its gonna fail. the newer pumps are much quiter, but i was quoted approx 1200+ CND for a new pump. I have a 2003 cooper, and the whining noise is loud. only once has the steering been really stiff, but i resolve that problem by restarting the vehicle. watch out tho, the power sttering could fail on you while your driving around a corner, and if you dont have both hands on the wheel, you'll go strait.
Sep 10, 2008 | 2003 Mini Cooper
HP PSC 2175 All-In-One InkJet Printer Logo
226 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
