SOURCE: Hi, Have a Kyocera KM4050 copier/scanner/printer
First you have to get into the maintenance mode. It is important once in there you don't make any changes other than the one I tell you or you could damage the machine. 1. Press the start key. 2. Select the [INITIALIZE]. 3. Press the start key. 4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically. 5. Press the indicated three + keys, and then check the display. 6. Press the stop key. The screen for selecting a maintenance item No. is displayed. Completion
To get into maintenance mode do the following:
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
