Xerox Phaser 3200MFP/N Laser Printer Logo
Posted on May 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dark strip down center of page when coping from tray
When placing copies in tray at top the resulting copies have a dark strip down the center. If we copy from scanner the copies are clear
thank you
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on May 08, 2008
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1110229
Points
5835
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
Luis Arellano
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 14, 2015
Luis Arellano
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6257
Points
5
I own 2 MFC-7340's. As described in a previous answer, a vertical black line down the whole printed page is usually the result of an ink spot on the 1/2" strip of glass. I like writing with gel pens but they leave little gobs of ink and the script takes a while to dry. Ordinary ballpoints can do this, too. These gobs smear onto the glass scanning strip and that causes the black line on your print from the gob downward - and also on every succeeding document! Before you feed your documents, use the heel of your hand to blot any fresh script and then lightly sweep your fingers over the page to disperse the excess ink. The rubbing will cause some minor smearing, so if the image must remain sharp, just let it dry completely or (at the risk of putting dots of ink on the flatbed, which could potentially transfer to the white pad above) scan it on the flatbed. If you get a stripe, a dab of spit and a few wipes with a finger across the glass usually get rid of it. Take note if you do a lot of scanning, you should view a sample scan onscreen occasionally to make sure you haven't picked up a stripe.
1helpful
What will be the reason for canon sensys fax-L 150 coping dark page but faxing and printing is ok.
First things first. Try and print report from the fax. Any kind of report. If it is printing OK, then the next step is to check if:
Your clients receive your faxes OK? If they are dark as well, then your scanner head is at fault.
When you make Copy on your fax and it prints dark it could be simply set with dark settings _or_because of the white calibration strip or roller being soiled or dirty, which acts as the ultimate white reference point for scanner _or_ the Scanner CCD sensor is in paper jam release position (too far away from reading the originals) just pull it back to normal feed position.
Or simply faulty scanner.
2answers
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Printer doesn't copy
indicates that the page on the scanner is upside down
the printed side faces down
13helpful
2answers
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
2answers
Dark strip
LIFT THE COVER UP AND CHECK FOR A SOMETHING ON THE NARROW GLASS IN FRONT OF WHERE THE FLAT BED SCANNER SCANS .
COULD BE WHITEOUT OR GREASE MARKER OR EVEN A DIRTY PEACE OF PAPER
5helpful
3answers
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
1helpful
Not printing properly....alignment
It is possible that the guides in the paper tray have moved?
If they are universal trays (meaning they are not locked down to only use one particular size), they could have easily shifted, causing what you have described.
Try copying using a sheet of paper through the bypass tray, and see if the image is centered. This will at least narrow down the problem to a particular tray.
7helpful
3answers
Printer putting line down the page
I had a hp 3050 yesterday with two vertical lines running down the page when making a copy. All I had to do was to pull open the top cover where you put the paper you want copied and cleaned the glass strip with a rag and alcohol and the lines were gone.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
