Can I use voice record in combination with the timer shut down function?
I'd like to run the voice recorder for 2 hours, then have the unit power off automatically. Is this possible, or will the recorded voice file not get saved (and so be lost) when the unit shuts down? I want to know that the player has this capability before I buy it.
Also, how many bytes per hour does the voice recorder consume?
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Most digital voice recorders, have a filing system. It is usaully labeled either: A, B, C, D or 1, 2, 3, 4 (these are the main folders) and each of these folders contains a set amount of files (in most cases about 99 subfolders). So you can have folder A file 1, 2, 3 and so on... When pressing the RECORD button for the first time you are in one of the main folders and your recording gets a sub folder number. To continue recording where you left off last time or where 'stopped' use the PAUSE and not the STOP function. The moment you press STOP instead of PAUSE you will change the sub folder number - and therefore not have one continous recording. If you turn the power off or remove the batteries you will also change the sub folder number. Most of the better recorders have a voice activation function that places the recorder on pause automatically when there are no sounds. It will not change the sub folder number when it starts recording again - and will automatically pick up where it left off.
Hello
The recorder should be formatted only by using the internal FORMAT function found in the Menu. Formatting using the computer may corrupt system files needed to run the recorder and may delete the Voice Guide Data and Audible system files, so computer formatting is not recommended. When the recorder is connected to a computer, individual files can be deleted using My Computer without negative effects.after you format the unit this is how needs t
be depends on your selection for Audio quality
STEREO XQ mode: 17 hours 30 minutes STEREO HQ mode: 35 hours 10 minutes HQ mode: 70 hours 20 minutes SP mode: 138 hours 30 minutes LP mode: 275 hours 20 minutes
if this don't solved your problem you can get one really cheap athttp://www.tvps.com/Products/Olympus-DS-50-1-GB-Digital-Portable-Voice-Recorder---Demo-DS50__OL-D-DS-50.aspx just like a back up
Hi, this is a defective power board fan in this device. the power board fan should be replaced in order to prevent the down time due to over heating. i will post a link to the replacement fan below.
It could be corrupted file. Try downloading one file at a time through My Computer. After you have exhausted all possibilities, format the recorder through the recorder (not the computer) and your memory should be fine
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
try using the power pack instead of batteries. Be sure to remove the batteries before using power pack, you can wreck the machine if you do not remove batteries. NEVER use the H4 on power pack while there is batteries inside.
1.In the stop mode, press and hold down the MENU/STOP button for at least 2 seconds The menu setting display appears. 2. Press the SKIP/SEARCH button repeatedly to select dAtE 3. Press the POWER/PLAY button. The year display blinks 4. Press the SKIP/SEARCH button repeatedly to select the year. Then press the POWER/PLAY button. The month display blinks. 5. Repeat the same step 4 to set the month, day, hour display ("24 H or "12H") hour and minute. Note: "second" cannot be selected. When the minute setting is completed, "dAtE" returns. 6. Press the MENU/STOP button.
