Loews has similar units starting around 159.00. Once you have determined it is really nonfunctional, it will likely cost more to repair it than to replace it. Sounds like it had a good long run, though. As to removing it , there should be a removable trim panel on the top or fasteners in the side or top cupboards to remove. Then you have the vent and electricity to disconnect. Be sure the proper breaker is off when you do this (mandatory safety nag). Hope this helps some:)
Farmerbear
The magnetron in your microwave has probably gone out. The magnetron is the
part of the microwave oven that produces microwaves. If you unit is a built in model,
it will likely cost more to fix than a new one. Same thing goes for a
countertop unit.
