Canon DR-9080C Path-Through Scanner Logo
Posted on Aug 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can any one help to find product that uses validated keypad code entry that could "unlock" the device and take copies and lock Once that is done, for canon 3300 copiers.
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Aug 30, 2010
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
247093
Points
823
The Canon 9080C is purely an input device and cannot 'take' copies, however it can scan any A3/A4 document which can be printed or emailed. By printing you get the copy. Technically it is possible to control the software/Computer through Software password.
S. Mohan
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Where is the alarm system on 2005 lincoln ls?
Anti-Theft - Perimeter The anti-theft perimeter protection feature is controlled by the front electronic module (FEM), the rear electronic module (REM), and the driver door module (DDM). The alarm can be armed using:
  • the LOCK button in the remote keyless entry (RKE) transmitter to the DDM, which sends a message through the standard corporate protocol (SCP) communications network to the FEM.
  • the driver or passenger door lock switch if the corresponding door is open when LOCK is actuated.
  • the key in the driver door lock cylinder.
  • the RKE keypad by pressing 7/8 and 9/0 simultaneously.
The FEM and REM then monitor all features, which activate the alarm in the event of an unauthorized entry.
The luggage compartment lid lock cylinder does not disarm the vehicle's perimeter alarm. The luggage compartment alarm can be temporarily inhibited through the luggage compartment lid disarm switch, located in the luggage compartment lock cylinder or by opening the lugguage compartment with the RKE transmitter or the RKE keypad. Once the luggage compartment lid closes, the perimeter alarm system immediately starts monitoring the luggage compartment. The perimeter alarm can only be disarmed:
  • by unlocking the vehicle using the RKE transmitter.
  • by unlocking the vehicle using the driver door lock cylinder switch.
  • by cycling to RUN a valid programmed key in the ignition switch.
  • by entering the correct vehicle unlock code on the RKE keypad.
Additionally, an ignition switch tamper circuit and a signal hardwire line from the FEM to the REM are monitored.
If any of the above features receive any activation once the alarm is armed, the alarm activates the visual and audible alerts. ......
How to reset anti theft system
KEYLESS ENTRY SYSTEM You can use the keyless entry keypad to:• lock or unlock the doors without using a key.• open the trunk.• recall memory seat/mirrors/steering column/adjustable pedals positions1 or 2. The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner's wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also create your own 5-digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation. Programming a personal entry code. To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. Note: The lock motors will cycle, locked then unlocked 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. Enter a sixth digit to indicate which personality feature should be recalled by the personal code. Note: The lock motors will cycle, locked then unlocked. • 1 • 2 recalls driver personality 1. • 3 • 4 recalls driver personality 2. • 9 • 0 does not recall a driver personality. Wait 5 seconds without pressing a keypad button in order to store a personal entry code. Tips: • Do not set a code that uses five of the same number. • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. • If you set a personal code and store it over an existing personal code it will erase that personal code only. Erasing personal code 1. Enter the factory set 5-digit code. 2. Press and hold the 1 • 2 for two seconds and release; this must be done within five seconds of completing step 1. 3. Press and hold the 1 • 2 for two seconds to erase the customer programmed code; this must be done within five seconds of completing step 2. Your personal code is now erased and only the factory set 5-digit code will work.
1helpful
Just purchased a 2003 mountaineer from a used car dealer and they don't have the manual and the alarm doesn't work. How do I get the factory entry code?
the keyless entry code is on the module and in the module memory. A dealer can extract the code ( about $50). You can access the owner manual on line at motorcraft.com, pro center, tech info, owner manual. I have one for $7 plus postage. let me know. Also, look for a plastic credit card in teh glove box with the code on it. The module should be under the dash, driver side I think.
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it overwrites the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
The system now responds only to the factory set code.
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad flashes during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after one minute of keypad inactivity.
Unlocking the Doors and Liftgate with the Keyless Entry Keypad System
To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will illuminate.
To unlock all doors, enter either the factory set code or the personal code (driver door unlocks) and press the 3/4 control within five seconds.
To open the liftgate window glass, enter the factory set code or the personal code (driver door unlocks) and press the 5/6 control within five seconds.
Locking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time
3helpful
I don't have a manual for my 2004 lincoln Avaitor but would like to know how I can change the code on the drives door key pad
KEYLESS ENTRY SYSTEM With the keyless entry keypad, you can: • lock or unlock the vehicle doors without using the key. Your vehicle has a factory set 5 digit code that operates the keyless entry system. You can also program your own 5 digit personal entry code. The factory-set code is located: • on the owner's wallet card in the glove compartment • or at your dealer. When pressing the controls on the keyless entry keypad, press the middle of the controls to ensure a good activation. This system will disable the power door lock controls. These will not work until the vehicle is disarmed. Programming your own personal entry code To program your own code: 5. Enter factory set code (keypad will illuminate when pressed). 6. Press 1/2 control within five seconds of step 1. 7. Enter your personal 5 digit code. Enter each digit within five seconds of previous one. 8. After the code is entered, the locks will cycle, confirming that the new code has been set. Do not set a code that includes five of the same number or presents them in sequential order. Thieves can easily figure out these types of codes. Your personal code does not replace the permanent code that the dealership gave you. You can use either code to unlock your vehicle. If a second personal code is entered, the module will erase the first personal code in favor of the new code. Locks and Security 149 Locks and Security If you wish to erase your personal code, use the following instructions: 1. Enter factory set code. 2. Press 1/2 control and release. The system will now only respond to the factory set code. Anti-scan feature The anti-scan feature prevents repeated attempts at arriving at a valid key code. The keyless entry pad is disabled for 1 minute after 7 unsuccessful attempts (35 consecutive button presses) at entering a valid key code. The keypad will flash during this 1 minute mode. However, the 7/8 and 9/0 controls will still lock the vehicle. Anti-scan will be turned off after: • one minute of keypad inactivity. • the remote entry transmitter UNLOCK button is pressed. • the ignition is turned to the ON position. Unlocking the doors with the keyless entry system To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will also illuminate. To unlock all doors, enter the factory set code or personal code (driver door unlocks) and press the 3/4 control within five seconds. Locking the doors with the keyless entry system It is not necessary to enter the factory or personal code prior to locking all doors. To lock the doors: • with the driver's door closed, press the 7/8 control and the 9/0 control at the same time.
2answers
How do i reprogram keyless entry codes
door pad keyless codes?
in owner manual, enter permanent code and then press "1" and enter personal code, then press "1" again. Then both codes will work.
If you don't have manual, go to Motorcraft.com and click on technical resources and click on your year owner manual.
Each vehicle equipped with a keyless entry keypad is programmed with a five-digit entry code. This code is provided to the customer through a wallet card in the Owner Literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit must be entered within five seconds of the previous button press.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it will simply overwrite the previous personal code. To erase a personal code, carry out the following procedure:
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad will flash during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after any of the following events:
  • the keyless entry remote transmitter UNLOCK button is pressed
Unlocking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
2helpful
Need to reprogram key less entry. 2002 Ford explorer sport.
Keyless Entry Keypad FAQ Ford Explorer
  • Lock or unlock the doors without using a key.
  • Open the liftgate window.
  • Activate or deactivate the autolock feature.
Where the code can be found
  • This code is located on the owner's wallet card in the glove box
  • Is available from your authorized dealer via scan code
  • Is marked on the computer module
Computer Module location
  • 1995 thru 2001 is located in the jack storage compartment in the rear of your Explorer. First remove the panel to the jack storage compartment. Towards the front of this area you should see a metal box this is your auto-lock module(way up front next to your rear left passenger seat). On the back side of this is your 5 digit code factory preset code. It is hard to get to. To see it you will have to loosen, pull, use a flashlight or a mirror but it can be done.
  • 2002 thru 2007 is in the right panel behind the middle row window. It is below the seat belt mechanism. You have to pull out the top plastic panel off, then loosen the lower panel to be able to see the face of the computer module. The code is on a sticker on the face of the module.
Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5�digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
  • 1. Enter the factory set code.
  • 2. Within five seconds press the 1 � 2 on the keypad.
  • 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
  • 4. Press 1 � 2, 3 � 4 or 5 � 6 to indicate which of the three personal entry code positions you wish to use.
  • 5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
Tips:
  • If you program a code to a position that already contains a set code, the previously-set code will be erased.
  • 1. Enter the factory set 5�digit code.
  • 2. Within five seconds, press the 1 � 2 on the keypad and release.
  • 3. Press and hold the 1 � 2 for two seconds. This must be done within five seconds of completing Step 2.
All personal codes are now erased and only the factory set 5�digit code will work.
Anti-scan feature If the wrong code has been entered 7 times (35 consecutive button presses), the keypad will go into an anti-scan mode. This mode disables the keypad for one minute and the keypad lamp will flash.
The anti-scan feature will turn off after
  • One minute of keypad inactivity.
  • Pressing the UNLOCK control on the remote entry transmitter.
  • The ignition is turned to the 3 (ON) position.
Unlocking and locking the doors, liftgate and liftgate window using keyless entry
  • To unlock the driver�s door, enter the factory set 5-digit code or one of the vehicle�s personal codes.
  • Each number must be pressed within five seconds of each other. The interior lamps will illuminate.
  • To unlock all doors and liftgate, press the 3 � 4 control within five seconds.
  • To open the liftgate window, press the 5 � 6 control within five seconds.
  • To lock all doors, liftgate and liftgate window, press the 7 � 8 and the 9 � 0 at the same time.
  • Note: The driver�s door must be closed. You do not need to enter the keypad code first.
Deactivating/activating autolock
  • Your vehicle comes with the autolock feature enabled.
Note: The autolock feature can be activated/deactivated independently of the autounlock feature.
Before following the activation or deactivation procedures, make sure that the anti-theft system is not armed, ignition is in the 1 (OFF/LOCK)position, and all vehicle doors, liftgate and liftgate window are closed.
*Keyless entry key pad procedure
  • 1. Turn the ignition to the 1 (OFF/LOCK) position.
  • 2. Close all doors, the liftgate and liftgate window.
  • 3. Enter 5�digit entry code
  • 4. Press and hold the 3 � 4. While holding the 3 � 4 press the 7 � 8.
  • 5. Release the 7 � 8.
  • 6. Release the 3 � 4.
The user should receive a horn chirp to indicate the system has been disabled or a chirp followed by a honk to indicate the system has been enabled.
Autounlock The autounlock feature will unlock all the doors when: � the ignition is in the 3 (ON) position, all the doors are closed, and the vehicle has been in motion at a speed greater than 12 mph (20 km/h); � the vehicle has then come to a stop and the ignition is turned to the 1 (OFF/LOCK) or 2 (ACC) position; and � the driver door is opened within 10 minutes of the ignition being transitioned to the 1 (OFF/LOCK) or 2 (ACC) position.
Note: The doors will not autounlock if the vehicle has been electronically locked before the driver door is opened.
Deactivating/activating autounlock - Keyless entry key pad procedure Your vehicle comes with the autounlock feature activated.
  • 4. Press and hold the 3 � 4. While holding the 3 � 4 press the 7 � 8 twice.
The keyless entry touch pad can use two codes. The factory code and one
personal code .
To program your own personal code, select a 5 digit code that doesn't use 5 digits in
sequence or the same button 5 times.
Enter your factory code
Within 5 seconds press the 1/2 button
Within 5 seconds of pressing the 1/2 button, enter your 5 digit personal code,
pressing each digit within 5 seconds of the previous digit.
You can now use either code to operate the keypad
Setting FOB to work with your vehicle
  1. Sit in car, doors closed. Electronically unlock all doors using the power door unlock switch on the driver's door.
  2. Insert key into ignition switch and turn from OFF to ON 8 times within 10 seconds with the 8th time ending in the ON position. (5 times on some models)
  3. The doors should lock and unlock by themselves to signal programming mode.
  4. Using your remote: lock the doors.
1helpful
2answers
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
External Control and Scan counts of DR-9080C
THe scan count is available in the control panel (under scanners...) and if the user is a non-administrator, he/she cannot reset it.
Canon 9080C permits installation of a mechanical counter inside the scanner. This can help you track the scanned quantity.
The way your question is detailed, I am sure you must be aware of these facts!
S. Mohan
3answers
Keyless entry
I believe dealer has to re-program the new code.
old marine
old marine
ZJ Limited
ZJ Limited
