Remote display go to website to update settings It appeard to be stuck at this point can none of the buttons work. It looks like the update remote works but then nothing.
How to
connect your Wii to the Internet
Power on
your Wii console and press the A Button on the Wii Remote to reach the Wii main
menu. Use the Wii Remote to select the "Wii" button. Now,
select "Wii Settings" to access the "Wii System Settings"
menu. Using the arrow on the right side of the screen, scroll to page
two and select "Internet." Select
"Connection 1: None"(Don't see "None" in Connection 1?
Click the Connection 1 button, then chooses "Clear Settings.") Click on
"Wireless Connection" and then "Search for an Access Point Select
"OK" and the Wii will display all the wireless networks it finds. Select
the wireless network that is yours Select
"OK," "Save Settings," and then "Yes."The Wii
console will run a connection test with your wireless network when the test is
completed. You should see the following screen.Then you're almost done! After
your connection test, the Wii console will check if there is a new Wii System
Update available. Once you select "Yes" and "I Accept," the
Wii will begin to download any available updates...
Click here to download repair guide
Power on
Click the Connection 1 button, then choose "Clear Settings.") Click on
· The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen.Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.
Power on
Point." Select
Power on
menu. Use the Wii Remote to select the psp" button. Now,
select "psp Settings" to access the "System Settings"
Point." Select
"OK," "Save Settings," and then "Yes."The psp console will run a connection test with your wireless network when the test is completed. You should see the following screen.Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the psp will begin to download any available updates.
Power on
Point."
Select
"OK," "Save Settings," and then "yes".
What I did to fix this was create a new account and added 1 device and activity. Then save it. This appeared to clean out everthing on the harmony 880. The I logged back into the orginal account and uploaded the old configuration. Now everthing is back to normal.
