Hi my freezer is working fine, the frige seems to work for a few days then stops working , we have replaced the fan, and the main circuit board, but it still seems to keep doing it, also the little led lights that come on and change when you ajust the interal frige controll (touch controll) seems to seize up when the frige stops keeping cold, freezer still keeps on working fine.
Thanks guys
The problem is most likely a thermal fuse, located in the freezer on the evaporator, has blown. The lights on are indicating an error code. If you unplug the unit and then replug it, it will run until it hits the defrost cycle. This will at least keep your food cold until you can get service.
Sgt 48
It could be a thermosat
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
I'm having the exact same problem. When I unplug/plug back in, the fridge will cool for awhile, then go off. The lights that indicate the cooling settings (1-7) will come on for a little bit, then go off. I noticed the same setting for the freezer temp will come on, but for 2 numbers instead of just the setting I pick.
Can I get the fuser and replace it myself? Are there any instructions for doing this? Thanks for the help!
I have the same problem. Didi you find out what is wrong?
