Archos 705 WiFi Digital Media Player Logo
Posted on Aug 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you advise where I can buy a replacement screen for my Archos 705
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Aug 28, 2010
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232894
Points
12714
Hi
You can order the screen for the Archos 705 from this link---
Archos 705 replacement screen
Link 2
Hope this helps...
Daniel
I have an Archos 705,it has been absolutely brilliant.But I plugged it in to its docking station to charge it up,to watch a movie through the TV,and there is absolutely no life in it?the machine is not...
Is there any way that the docking station has something in it that might cause a poor contact between it and the device?
Especially if there are children in the house!
1helpful
My archos 705 wifi will not hold its charge....help plzzz
There is a known issue with archos players since Gen 04 that causes them to discharge more quickly if left in their charging stations (DVR dock) after the full charge light begins to flash. If you charge the unit this way, your battery is probably toasted. Good news is that the 705 battery is user replaceable. Bad news is its over 40 bucks. Try newmp3technology.com or ebay for a good price on a new battery.
Stuck on the ARCHOS Screen and it won't do any thing
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Archos av700 screen has yellow/green tinges
i know this may sound weird but put it screen down for 24hrs i had the same problem after i did that it went away
3helpful
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
B) The Archos 705:
C) Computer
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
Battery difference between archos 704 and 705 (wifi) ?
I use the same batteries in both units. The only difference is the colour of the back plate and the label on the inside. Clone and extended batteries are different backs anyway.
I can not put video to my archos 705, please help me
You need to buy DVR docking station and Movie plugins.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
