SOURCE: Unable to rewind film in camera
Well, I used to work at a camera store and actually encountered this a number of times with Minolta's. I can't remember if the motors wore out or if the film slipped or tore at the track. The solution: take the camera into a darkroom or pitch black environment and remove the film by hand. Bring a pair of scissors and a black film container just in case the film tears or the track is torn. Obviously be careful to ensure no light is available if you can't access a darkroom. Check the bottom of the camera for a small button that disengages the motor gear (some newer models may not have this)(you may have to hold it in). Open the film door and with clean hands, use your index fingers and thumbs carefully on the tracks only and pull evenly. You may feel some resistance from the motor and hear the motor but if it won't budge check again if the bottom of the camera has a film release. As you do this feel for torn areas in the track which may indicate a motor malfunction or improperly loaded film. Now just wind the film back into the canister unless the track is torn. You may want to leave the leader out, and you should probably have the film developed right away for a list of reasons. If the track is torn, cut it off at the canister and touching only the edges roll it up and put it inside the plastic film container. Mark it "open film", or Open only in darkroom etc. and mention it to your developer. Alternately you can just hand over your camera to your developer who will do all of this for you...
SOURCE: My camera doesn't work when I press the shutter release
I think the timing of the shutter winding gears has slipped a tooth or two. look at the picture in this image:
http://www.twid.de/x700/pic03.jpg
Near the motor drive coupler at the bottom you will see a blue and a white gear. Look closely at the blue gear and you will see a line on the top of it. That line needs to be pointed at the center of the white gear when the camera has been released and ready to be advanced again.
If you wish to proceed, I will tell you how to re-time the gears.
SOURCE: Minolta 35mm X-370 stuck shutter
You are probably on the right track with the batteries. Stick some fresh ones in and the shutter should release. Your may need to use the advance lever to re-**** the shutter and drop the mirror down. You could also try removing the lens and manually pushing the mirror down to see if it stays in the down position.
SOURCE: when I look through the viewfinder of my camera I see blue streak
This isn't really a solution, but when I check "I have similar problem", it takes me to a different page all together. The first time I heard about a blue glow in the viewfinders of late-model Maxxums was in reading an eBay guide written by J.D. Katz. I didn't really believe him until my own Maxxums started doing it. Apparently Maxxums 3, 4, 5, GT, QTsi, STsi, HTsi, XTsi and probably the 50 and 70 are susceptible. All were assembled in either Malaysia or China and all have penta-mirror viewfinders. Both my Maxxum 5 and my XTsi just recently started doing it: the 5 has sapphire-blue streaks on either side of the viewfinder; the XTsi's viewfinder has just a faint blue haze. Probably some coating on the glass inside the viewfinder is breaking down with age. It's a shame because they are otherwise excellent cameras. While it is an annoyance, it is confined to the viewfinder and should not affect the images taken. Probably won't have much luck getting Sony to do anything about it either, since they're film cameras and they're getting old....
SOURCE: I have a Minolta XG 2 where the shutter release
opem the battom cover,along the realease button u will find a lever,move it to get realease the shutter,reapeat it a dozen times,then try as usual
