Remove the battery and also the memory card and keep aside. after about 30 minutes reinsert the battery and hold down OK button, then switch on to see if the camera resets with the lens correcting. If the fault does not clear, repeat once again but hold the lens on the palm and tap softly to reset the mechanism from any blocks.
If none of the above works you will need help to open and check.
