Question about KitchenAid KCMS145J Microwave Oven
I have a microwwave oven that turns on but will not heat. It has never worked. Is this an install problem or unit problem? KCMS145JSS
  • KitchenAid Master
  • 17,130 Answers
You will need to check to find out if the microwave has all the power coming to the critical units.
If the latch switch is active then the turntable and fan must work but if there is no heat, the check on the thermal cut off switch fitted on the side of the cabin , if faulty. , the pwoerr will be cut off to the magnetron. Check also to confirm that the high voltage capacitor is working and not shorted or open.
The relay on the main boarrd also must click to switch on or else the relay or relay drive must also be checked out.
Posted on Aug 27, 2010
6ya staff
SOURCE:
How do i get control panel of jvm3670sk02
see the diagram attached: God bless you
Sep 09, 2012 | Microwave Ovens
I have a Kitchenaid microwave model KCMS145JSS-0. It is no longer heating. What can I do to repair it?
Check the door safety interlock safety switches for proper operation. You will find them inside the cabinet.
If they have failed, the oven thinks the door is open and therefore will not turn on the heat. This is the most common reason for failure.
May 30, 2011 | Microwave Ovens
When I turn on the micowave; smell somthing burning
The magnetron (the part that heats the food) may be ready to burn out. If you smell the burning, you should then unplug the microwave, open it up and see if you can determine for sure that it is coming from that part. Unfortunately even if I am right, it is almost more cost effective to just replace the microwave rather than replace that part. You can run this microwave till it dies if you want, but I would be ready with a new one.
Let me know how this works out for you.
Benjamin
Apr 29, 2010 | KitchenAid KCMS145J Microwave Oven
Maytag microwwave oven
check the magnitron and capacitors one of this bad
Sep 18, 2007 | Kenmore 80412 Microwave Oven
Microwwave
Could you be more specific as to what it's doing and not doing and when? Thanks.
Mar 12, 2007 | AEG MC143EUX 750 Watts Microwave Oven
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
162 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
