If you have checked the charger and are sure it isn't working. Then you have two options: You can buy a new on-board charger or try to locate a good used off-board charger from someone in your local area. Or maybe borrow one from a neighbor that has a power chair to see if it will charge your batteries. You just plug the off-board charger into the charger port located under the front of your joystick. Off-board chargers should be cheaper than an on-board from Pride. Hope this helps
Testimonial: "Very helpful. Thank you."
