Hello, PJ1989 -
I suggest you contact NordicTrack Customer Service directly and explain your problem:
https://support.nordictrack.com/contact-us/
You may need Nordic Track authorized repair service.
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
SOURCE: NordicTrack C2200 treadmill quit working. No power.
If your computer does not come on at all: Start with the line cord and make certain that it is not damaged. Buying a cheap digital volt-ohm-meter can help a lot. Once you are sure that there is AC in the PS, read the label and check all the wires if they have their proper voltages. You will come to the point where the power is interrupted. Simply replace or repair that part. Of course we will be standing by to help you. Please, whatever you do or how tempted you are DO NOT TOUCH THE MOTHER BOARD. We will help you with that headache once you get to have power. Thank you for considering our service.
My name is Constantin (arzconst)
SOURCE: with Nordictrack C2000 checksum : fail appears on
This is a sign of a bad console. They may be able to flash the machine using the i-fit sd card slot. Go to iconservice.com for contact info.
SOURCE: Philips 42PF9630A/32 Plasma TV RED led blinking 7 times
Are there any blown caps on the PSB-power supply board. Most sets have sammy boards and they used very shotty caps. If there are no visual clues being a poped cap at the top (X) they simply often do vaporize and dry out. The YSUS-Main and the 2 Y buffer boards control the picture OSD-on screen display. Your not getting any of that. So power supply is where you start first. The YBU-upper and the YBL-lower control the upper and lower OSD the Ysus main control both of them. Usually if you have one in the door you have to replace all 3. But not always. If you were to replace any of the boards I would replace the YSUS-Main, or get the board reworked at a pc repair shop that does board level test and repai. Its more cost effective.
Best Regards and Semper Fi
