DeLonghi Pinguino PAC-GSRU Air Conditioner Logo
Posted on Aug 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My delonghi pinguino pacl17 does not cool enough, doyou have a telephone number i canreach you. It only cools to 64 and its not cooling enough,
Anonymous
Level 3:
  • DeLonghi Master 43,501 Answers
  • Posted on Aug 30, 2010
Anonymous
DeLonghi Master
Level 3:
Answers
43501
Questions
0
Helped
10837811
Points
101584
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
1helpful
I just bought a used DeLonghi Pinguino PAC 02. It seems to cool ok but the exhaust hose gets very warm. Is that normal?
Yes, that is normal. It's exhausting the heat from the compressor out the window.
Thanks for choosing FixYa.
2answers
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Delonghi PAC F10 air conditioner doesn't seem to be cooling
It could well be low on refrigerant, as well as a multitude of other possibilities. I'd have it serviced by a pro.
DeLonghi Pinguino PACL90 MODEL
For a short time you can run without filters. I suspect it is low on charge or the metering devise is not working. Check this link out for an owners manual. It may help you.
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Pinguino pac-166 not cooling enough
CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
