Remove the battery cover (bottom part of the g-shock). Unclip the battery poistive holder. Replace the battery. If the screen goes off, you need to connect (jump) the 'AC' hole with the pos (+) side of the battery for two seconds using a thin piece of wire in order to reset it. Put the g-shock back together.
<P>Thanks for contacting FixYa.</P><P>Found a great tutorial for you.</P><P>Ive been changing batteries for 25 years and I wouldnt touch this one, so best of luck to you!!</P><P><A rel='nofollow' href="http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html">http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html</A></P><P>If you do this one, then you should get in the biz for sure!!</P><P>Jewel</P>
