Bro... i'm warren from philippines... try my solution... insert you mmc
to your reader and connect it to your personal computer (USB).. if your
computer is having a problem to open that removable drive its ok..
don't worry about that i have solution with that later... then if your
computer is having a problem detecting your removable drive be sure
that you reader is working correctly.. if your reader is working maybe
your mmc is broken...things you do.. REPLACE IT..!!! lets go back in
other solution, if your computer is having a problem to open that
removable drive (it means your memory detects by your computer) try LOW
LEVEL FORMAT YOUR MEMORY CARD..install a low level format to your
computer then format that mmc, then insert to your cellphone and format
it to FAT..
here's the link for low level format tool...
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
i hope this solves your problem..
e-mail me at [email protected] if theres anything.. ^_^
i post this solution to another problem here in fixya..because his problem ad your problem has the same solution..
To format your memory card:
Menu/Tools/Memory card/Options then Format memory card.
"I don't want to achieve immortality through my work, I want to achieve it through not dying."
Find your solution from the list, Software & Hardware Problems Find Solutions for Nokia Phones:
Nokia N70
Codes:
Nokia N95
Nokia N73
Nokia 6300
Nokia 6600
All the other Nokia Phones.
I have nokia-6680 mobile the one GB MMC of NCP company is corrupted. I tried over computor and thro mobile phone formatting tools but failed to achieve. pl suggest correct way to format it.-----S.P.DABADE
try by restoring handset once a time or else memory card is corrupted..change it....
Dear Sir,
i m suffering with problems also formating my mobile and MMC as well so kindly give me some specail codes for formating or flash my mobile like a new
when i insert mmc card MU13 in my cellphone N70 it says memory card corrupted In pc I can't format pc says card is write protected
same
Hi! when i was copying some aac format music files to 1GB mmc of My N70, suddenly, in my file manager it was disappeared. I gently removed connection and open mmc option in my mobile. then it said file corrupted, format it! I agreed to it. and I formatted it. and then I again tried to copy some files into mmc through pc suite. again mmc was suddenly disappeared. and in my mobile i found a message there is no mmc is inserted.
how i can fix it, please give me suggestion,,,,
we have same problems..my mmc mobile card is corrupted too..when i try to format it in my n70 phone.it does not work.also in pc it does not work also..I/O device error is appearing when i do it..how can i fix this problem!!!im mad trying to solve it..pls help...
when i insert mmc card MU13 in my cellphone N70 it says memory card corrupted. In pc I can't format pc says no card inserted. Pls give me a solution, there is no way to format.
Last Joke
mmc
when memory card inserted shows a memory card not formatted
