Question about NRS Hoveround MPV 5 - Used Power Wheelchair
I have a 3 week old (bought new) MPV5 Hoveround that has a noisy thumping motor/wheel. What is wrong? ronnancyb@comcast.net
  • 692 Answers
Contact Hoveround it is under warranty
Posted on Aug 28, 2010
6ya staff
SOURCE:
How to locate and replace a fuse or fuses in a Hoveround MPV5
Here is te user manual to replace the battery where you can also find the fuse:
https://www.hoveround.com/Hoveround/media/Document-Library/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
May 03, 2017 | Health & Beauty
Hover round mpv5 , what size wench to remove tire
To remove Drive wheel 15mm 17mm 19mm are normal sizes, to separate the split rim for tire replacement, 7/16, 3/8. I would use a socket set.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 28, 2016 | Hoveround MPV5 Electric Wheelchair - Used...
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
Wt is the tire psi for mpv5 middle tire
The pressure is 50 PSI, but 45 PSI worked better for me.
Sep 30, 2014 | NRS Hoveround MPV 5 - Used Power...
How do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
Sep 27, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
How do i replace hoveround motor?
First off, are you sure it's the motor causing the problem? Changing the motor is a major job. Basically, you have to completely disassemble the entire unit.
Remove the seat and then the batteries. To get to the drive motor, you must remove the pedestal base, and the plastic shroud that covers the base plate. Remove all screws from the top of the unit, and flip over and remove the bolts from the bottom. The control box is held in place by 2 hex screws. Label the motor wires showing their location. Remove motor and replace with new drive motor. Attach motor wires and reassemble entire unit.
Aug 31, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
Can a joystick controller from a hoveround mpv5 chair work with a heartway allure chair
They both have VSI joystick controllers. There are many variations of connections but as long as the connections match up, there should not be a problem switching them.
Aug 24, 2014 | Heartway Allure Power Wheelchair
Where can I get a manual for a Hoveround MPV5 wheelchair? I bought a used one, but no manual.
This manual is a hard one to get. You will have to call Hoveround. If you would like, Click the link below and it will take you to Hoveround's web site.
http://www.hoveround.com/wp/products/power-chairs/mp5-power-wheel-chair/
Feb 07, 2010 | NRS Hoveround MPV 5 - Used Power...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
Top NRS Health & Beauty Experts
Vitally Alcher
ray gallant
ray gallant
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
