Question about Doro 730R Cordless Phone
Doro 5065R +3 not working after replaced battery
Hi, used Doro 5065R +3 for year, found that the battery of the handsets were end of life, called Doro and advised to take the battery from **** Smith. After replaced with DSE (brand name) NiMH rechargeable batteryHR03 1.2V 700mAh 70AAAHC, the charging seems alright, the signal shows strong but it drops out within 10 seconds on in-coming and out-going calls. Any reason for that ? I haven't kept the old battery but I can remember that was 500mAh, DSE told me that's not a problem.
Please advise.
    Problem Solver:
  • 3 Answers
You can find the manual here:
http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
HTH
Cheers!
Posted on Nov 04, 2008
I have replace my doro batteries with Duracell rechargeables, just make sure you fully charge them before you put them in the handset.  If you find after a time that the charge goes again, charge them again (in the charger you buy when you buy the batteries)! Hope this helps.  PS, do you know how to turn the answering machine on?
Posted on Jul 29, 2008
6ya staff
SOURCE:
Time keeps changing on my vetch DS6722-3. How do I correct this?
1.) The handset battery pack has to be properly charged in order to set any of the handset settings...if the battery pack in the handset is not holding the charge ~ then
2.) The rechargeable battery in the handset is at its end of life and will need to be replaced.
Jan 18, 2017 | Lands Phones
How to turn off mute on 2003 Doro modelno model no. on handset?
Open the battery comparment on the handset. Under the
battery there should be a small sticker with the model
number. Take this number to www.manualslib.com and
you'll be able to download the original users' manual....
which will then answer many questions.
Apr 22, 2016 | Doro Lands Phones
Typical battery life for cordless home phones
Rechargeable batteries will last 2 to 3 years so your experience is normal. Time for a new battery which is a common type. Can be found on Amazon and elsewhere. For example: http://www.amazon.com/T-Lucent-AT3211-2-Cordless-Battery-Replacement/dp/B0083YBU5O
Sep 15, 2014 | AT&T ATT AT3211-2 DECT 6.0 Digital...
We at CAAP Davao Philippines have a MGE Galaxy 3000 10KVa UPS with serial no. 13299-4. It was installed last 2003. We had three times replaced its batteries over the period of years, the latest was 2008....
On the Galaxy display you could see what is the remaining battery life time as calculated by the software. Normally after you replaced the batteries you are supposed to reset this counter using specific software by the manufacturer. According to your information you have replaced the batteries 3 times in 5 years period. This is not normal. Nevertheless since the last replacement in 2008 it appears that the battery are now reaching the end life, which is generally 3-5 years life expectancy.
I would review the following of the assumption that the UPS is fully operational and the charging system is working.
1. Do a load test or a battery impedance test to verify the batteries are good
2. I would look at the battery life time specification, whether it is 3-5 years, 5-7 years ect.
3. Check the room temperature, every 10 degrees Celcius above 25 deg reduces battery life time by half
4. Check the number of power failures/ duration of these power failures and if possible what load were on the UPS at the time of the power failures.
I hope this will help. If all verifications are to specifications, then most likely it is a software problem
Apr 01, 2011 | MGE Galaxy 3000 UPS System
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
User manual for DORO 5065R
I found the link @
Nov 04, 2008 | Lands Phones
I have a doro 640/650r cordless phone, two handsets.....one of the handsets seems to have frozen up and it has 3 symbols on the face...one is a lock which stands for 'Key lock activated' and I can't figure...
Problem fixed.......after a call this morning to Doro tech support. It was a simple fix..........simply hold down the # key to lock or unlock the keypad. Unfortunately I had overlooked that section in the manual.
Oct 08, 2008 | Lands Phones
Doro 5065R Answer system
Press message button on back of headset and then press the number 7 on keypad and it should go back on to turn off press the 9 key.
Jul 08, 2008 | Doro Lands Phones
Main handset won't work; additional handsets do.
Check that you have the larger power adaptor connected to the base unit.
May 16, 2007 | Doro 530 Twin Cordless Phone
Doro 730R Cordless Phone Logo
631 people viewed this question
Top Doro Lands Phones Experts
Marvin
Marvin
Vernon Taylor
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
