As an 880 owner myself, I think this is a common problem and documented out there on the internet.
This has happened to me a lot. (Okay, it's actually stopped now as the charged remote keeps shutting down and going into test mode.) But, back to your battery issue - I believe that the charging pins in the dock don't properly contact the equivalent pins on the back of the remote.
Try cleaning them with a Q-tip and rubbing alcohol, then press down. You should hear one beep only - if you hear a beep followed by another beep, the unit has made contact then lost it.
Good luck! I think this really is a design flaw.
