DeLonghi DE500P Dehumidifier Logo
Posted on May 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
De500p lost owners book
Need to down load directions for use
  • 1 more comment
  • Anonymous Jun 02, 2008
    Lost the owner manual for directions for use. Can't find it .
  • Anonymous Jun 19, 2008
    OWNERS MANUAL DELONGHI DEHUMIDIFIER DE500P MODEL
  • Anonymous Jul 13, 2008
    need to download copy of owner manual and use instructions
Anonymous
Level 3:
  • Master 828 Answers
  • Posted on May 09, 2008
Anonymous
Master
Level 3:
Answers
828
Questions
0
Helped
454780
Points
1944
Http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
This should solve your problem.
Idem didn't come with manual, need instuctions.
If you have the adobe reader on your computer, you can access the .pdf version at this link here http://www.appliancefactoryparts.com/dehumidifiers/delonghi/de500p.html. Adobe offers a print option for documents so you can print it out if your printer is ready
2helpful
I lost my manual can you help me turn the unit on- I can't remember what settings to use?
You can get the manual on the link below. Just type in the # code then click on download now. This is for the DeLonghi DE500P If that is not your model please give the make and model #
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate.
4helpful
2answers
Need instruction booklet
You can get the manual of the one that you have listed under on the link below. If it is not the right one please give us the make and model # so we may get you the right one.
http://www.sylvane.com/images/productpages/DeLonghi/Dehumidifiers/de400-de500-de400p-de500p.pdf
Good Luck and please rate 4 thumbs for the free answer
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
2answers
Need a part
This appliance has 3-ft drainage hose and a 16-ft pump hose. I searched for a store that carry these hose, unfortunately, none of them sell a part or accessory for the DE500P.
Kindly click this link and verify if they could sell a hose:
http://www.nextag.com/delonghi-de500p/compare-html
Good luck.
9helpful
DeLonghi dehummidifer de500p when i first plug it in comes on
DE500P does not run and shows error code E3. What part do I need to replace and where can I get it?
1helpful
2answers
De500p dehumidifier pump stopped working, help!!!
I only got as far as disconnecting the filter between the small water bucket and the pump. I was able to get the pump working again after I cleaned the water bucket and filter by flushing them repeatedly with fresh water. The lines after the pump contained cloudy water, but I figured since the pump was able to push it out past the pump already, it shouldn't cause problems this far down. It saved a lot of time and hard work not having to disconnet the rest of the tubing or take the water bucket off. I also realized if I disconnet the first water collection tubing from just under the front panel and point the open end down, all the water in the bucket flows out. This part is so easy to get to. Just pull out the big collection tank and it's right there on the left toward the back. I can do this every week! Maybe then nothing will sit long enough in the small water bucket to turn into any kind of filter-clogging material.
7helpful
Delonghi de 220 dehumidifier tasciugo
http://www.manualnguide.com/download/manual-guide/
The above URL will allow you to download instruction manual if a PDF format.
Top DeLonghi Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
