Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
We are trying to move the chair and the service light keeps coming on
  • 692 Answers
The service light indicates a problem. Count the number of flashes. ie flashes 4 times pauses flashes 4 times etc. If you have the owners manual the flash code section will tell you what the number of flashes mean: 3 flashes left motor 4 flashes right motor. You will have to contact a service company to repair the chair once you find out what flash code you have. If Medicare pirchaed the chair then they will pay for most of the repair cost. Hope this helps
Posted on Aug 25, 2010
6ya staff
SOURCE:
I am having a lighted wrench come on when I'm riding my jazzy elite he chair. Not sure why. Except portions of chair move slowly and makes a small grinding sound. Thank you.
The problem you have with the chair moving slowly and the grinding sound is the reason the light is coming on. It needs to be serviced soon before the cost of repairs gets larger.
Jun 17, 2017 | Elite Health & Beauty
The speed lights keep flashing. It still moves.
The speed light flashing usually indicate that the chair is in "Limp Mode" This could be either the motor is getting too hot or the chair has a lift on the seat. If the chair runs fine for a while and then this condition appears, you may have a bad motor or a brake dragging causing the motor to get hot. the controller will allow less power to the motors to help it cool down and still keep you mobile. If you have a lift on the chair that raises up the chair, you will have to lower the chair down to gain the full power back. If neither one of these solutions are the problem, then you will need a Tech to come out and look at the problem. you may have a more serious problem that a tech can troubleshoot.
May 11, 2015 | Pride Jazzy 1103 Ultra Standard Power...
Lights turn on cant move
Be sure the free-wheel \ brake release handles are set to drive\lock position prior to turning on. After that, if chair still does not move, you will need to count the flashes on the joystick to determine the error or issue with the chair.
A user manual can be purchased on ebay.
Nov 11, 2013 | NRS Hoveround MPV 5 - Used Power...
All the lights are blinking on the speed display.. we've had the chair plugged into both the back of the chair and the armrest.. the chair still won't move.
The speed display will flash whenever you have the charger plugged in. Either in the back or in the joystick. Hopefully you didn't have them both plugged in at the same time. If after you unplug the charger you still get the flashing speed lights then you have an inhibit problem with the chair. The inhibit function will keep you from being able to drive the chair while charging. This repair is beyond anything you can do and must be referred to a Pride dealer or Repair service Hope this helps you
Apr 22, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Chair was charged last night and now the power light flashes and chair will not move
NEW BATTERIES NEEDED TRY CHARGING CONSTANT FOR 16 HOUR IF POSS OR OVER NIGHT. IF BATTS KEEP FAILING THEN SERCH NEW BATTERIES ON THE WEB A PLACE IN WALES DO THEM NEXT DAY DELIVERY GOOD VALUE
Dec 24, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Dec 20, 2010 | Pride New Jazzy 600 Power Wheelchair by...
Lights on chair keep blinking and won't move
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Sep 13, 2010 | Jet 7 Portable Power Chair
Lights keep blinking and chair won't move
Yellow lights blink and chair does not move on Jet 3 power chair
Jun 15, 2010 | Jet 3 Ultra Power Chair
Batteries won't charge w/ on board charger-+
sounds like blown fuse which is at rear of chair. may be underneath rear cover. this fuse wont keep the chair from working, however, it will keep the charging from working.
May 29, 2009 | Invacare Supply Group Invacare Pronto M91...
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
268 people viewed this question
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
