Encore Software Kawasaki Jet Ski Watercraft for Windows Logo
Posted on Aug 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kawasaki jet ski starter motor removal - Encore Software Kawasaki Jet Ski Watercraft for Windows
David Belcher
Level 3:
President:
  • Master 1,978 Answers
  • Posted on Sep 03, 2010
David Belcher
Master
Level 3:
President:
Answers
1978
Questions
Helped
1001394
Points
6030
To get access to the starter you will probably have to lift the motor out of the machine. Most Kawaski hulls do not give you much room to work. When you take the exhaust off you may have enough room to unbolt the starter.
Need to replace starter bendix on 1994 750 kawasaki xir
It is fairly easy to change your starter bendix. Just start by disconnecting the battery cables. Then you will remove the bolts on the flywheel cover, which also hold the starter in place, and then just change the old part out with the new one.
Kawasaki watercraft
compression check , 100psi or more ! battery and connections good ?
''how to replace starter in 1993 jet ski''
Unbolt the electronics box (swing out of the way), take off the box mount plate, and remove the exhaust upper manifold and expansion chamber. This should give you good access to the starter.
2answers
How do you replace a starter on a 2003 kawasaki 1100 jet ski
You will have to unbolt and move the electronic box, unbolt and remove the upper exhaust manifold, and the expansion chamber . This should give you access to the starter underneath.
1helpful
How to replace seal on a jet ski
The seals in the drive pump can be replaced by taking off the ride plate and pump housing. To replace any other seals (engine or hull) you will have to remove the motor from the hull.
3helpful
I have a 1995 kawasaki zxi the bolts on top of
The numbers on the head are the torque pattern/order. Two stroke motors generally use a torque value of 18 to 22 foot pounds on the head bolts/nuts.
2helpful
3answers
1989 650 jet ski starter drive spins but not turning motor,drive is working fine when removed.
it is probably too wore out to crank the engine. replace brushes and bearings or find a new starter.
Removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
Jun 15, 2009 • Boating
Top Encore Software Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you an Encore Software Video Game Console and Game Expert? Answer questions, earn points and help others
