SOURCE: dash light problem
well since you changed the sensor did u reset the computer?
you will have to do that so the computer will no not to use back up and set it back to restored mode
SOURCE: Quits running and engine light is now on!
I am having the same problem... My solution was to check for pending trouble codes, which is a sensor about to go out... Mine was a crankshaft sensor b trouble code PO385 and PO356.. You might want to check it out...I have 80,000 mile today also 03 deville V8 4.6
SOURCE: 2003 Sonoma does not turn-over
U have lost the battery, check the cables, if they are clean (no corrsion) replace the battery, modern sealed batteries fail like this, crank fine and then puff nothing, happened to at least 5 times over the years and saw it all the time at work.
SOURCE: Truck will ot shift and speedometer stopped working too
Have somebody check for trouble codes.Look for possible speed sensor codes.The speed sensor is a input to both trans and abs.
SOURCE: check engine light and battery light
if you do anything you will void the warranty you really should return to dealership
