Question about Kenmore 83142 Electric Dryer
Went to turn on dryer, sparks came out of back of dryer. Dryer will not turn on and inside dryer light does not come on when I open door.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You have a bad connection where the power hooks up...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
2 Suggested Answers
Anonymous
SOURCE:
John Hall
  • 1218 Answers
SOURCE: Kenmore 80 Series Gas Dryer wont turn back on after blowing fuse
Good day,
First, reverse the washer and dryer plugs in the outlet.
If that works, then the outlet needs changed.
If not,
The light switch is hot wired to the light circuit. Which means, if the machine is plugged in, the light will work.
Two possibilities.
1.The cord is bad, and needs replaced.
2. The light switch, which also runs the circuit to the motor is bad.
To access the switch, remove the lint filter, remove the 2 screws under it, then with a screw driver, pry up the top lid, one side at a time.
Lift the lid, but do not go above vertical. You will see the switch, and how to remove it.
You will need a VOM meter to test these items.
As well, make sure the machine is unplugged.
The following clip, at the beginning will get you started if you have to access the switch.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Posted on Dec 21, 2009
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Replaced timer on dryer because would not shut off sometimes. dryer was working while I had it open I was vacuuming out lint around drum and switches. had door open and light was on suddenly light went out...
if its on a circuit breaker,just switch the breaker off,then back on,they can drop out ,but still show good
if this is not the case,check the incoming power block inside the dryer as a burned off neutral conductor can result in the same condition
Sep 11, 2011 | Dryers
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer drum sparks when i push on it
You have loose or shorted wiring in the dryer. Unplug the dryer.Raise the top lid. Remove the screws on the top right and left inside the dryer to remove the front panel. Disconnect the door switch wires and set the panel aside. Reach in under the drum and remove the drive belt from the motor and pulley. Remove the drum. Inspect the wiring visible inside. Remove the rear panel from the dryer and inspect all wiring and thermostats and fuse relays.Remove the terminal cover where the cord connects and inspect all wiring there for broke or loose. Open the control panel and inspect all wires there for broken or loose. Repair any wiring found defective and replace any parts found defective.
Sep 17, 2009 | Kenmore 83142 Electric Dryer
Has power but won't start. the light inside the
First, go to your circuit panel and turn off then back on the dryer breaker.Second, check for a broken belt. The belt switch will be open if the belt is broken and the dryer will not start. Next.Replace the thermal fuse located on the top right of the heater canister located in the inside rear of the dryer.
Aug 28, 2009 | Hotpoint Dryers
The light will not turn off and dryer wont run
CK,
There's a switch behind the dryer door. Push it in and out with your finger, you should here it "click, click, click" and the light should go on and off. If it doesn't, you'll need to replace the door switch.
If that's the case, I'll need the full model number. It's on a sticker on the front panel behind the door. (it should be like three digits, decimal point and about 7 more numbers... 110.*******) With that number, I'll be able to look up parts for you and guide you through this easy repair.
SG
Apr 08, 2009 | Kenmore 64952 Electric Dryer
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Dryer suddenly stopped - F&P ED56 Autosensing Dryer
what is the make/model of your dryer and does it have an electronic display? different solutions apply to different models thank you
Sep 09, 2007 | GE DVL223GB Gas Dryer
Kenmore 83142 Electric Dryer Logo
194 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
