Ok, this is a problem with that model printer.
Right click start, left click explore, click the + sign on the program files folder. Look for the Dell Printer 922 folder and
click on it. Look in the folder for dlbtjswx.exe in the folder and
double click on it. This should install it, if it didn't install. If
that doesn't work, then try re-installing the printer following the
instructions below.
Disconnect your printer. Download and run this patch (a MUST with Vista machines) to completely remove the printer from your computer.
Restart your computer.
Download the proper drivers
XP Drivers
Vista 32-bit Drivers
Install the proper drivers. You'll be prompted when to connect your printer.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
Thank you Thank you
worked great
