every cellphone has its standard battery... in nokia6300, the standard battery is BL-5C.... if you inserted it with different battery type... thats the result "charger not supported" in most cases.... or you are not using a standard charger.. check it out...
PLEASE DOWNLOAD THIS SOFTWARE TO YOUR PC AND SELECT MOBILE http://dc217.4shared.com/download/34SSmsiF/Nokia-charger-not-supported-So.rar?tsid=20101117-012046-fceb3897 AND SOLVE YOUR PROBLEM
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
firstly you have to repair your mobile charger place. if your problem remain then you have to remove your battery from mobile and charged battery with universal charger.
