Fossil BQ9177 Wrist Watch Logo
Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I SET THE LITTLE DAILS INSIDE OF WATCH?
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 23, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457851
Points
2634
How do you set the date on a tomato T13-3140 watch?
Hi i have a tomato watch with 3 mini clocks inside its the day eg. Sunday and the day of the month eg. 24th how do i change these little ones or is it not setable?
Mar 14, 2014 • Watches
2answers
Stopwatch
You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
2helpful
How to set the time on a digital watch
Hi, you need to find the little black "set" button which is located on the right side of the watch between the two functioning buttons. its very little. Press it once with like a needle or a pen tip (because you cant reach it with your fingers). You can then set the time.
Jan 12, 2014 • Watches
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 • Watches
1helpful
How do I set the little diles inside my watch?
Click on my profile (escapement), then click on Tips an tricks. There you will find link to all Fossil watch manuals. Rate me, plz.
3helpful
Steinhausen watch adjustment?
To set time, you need to unscrew crown anti-clockwise direction if you have a screw-in crown watch. You need to softly and slowly pull the crown out a little bit. The best way to do this is to use first and second finger and use finger knuckle as a lever in order to pull the crown out with as little force as possible. You can feel a little "click"! Now you can set the time by turning it anti-clockwise. This would turn the minute-hour hands forward until you set the right time. When time is set, push the button back and screw the crown clockwise for a few rounds to ensure it is screwed back tight.
May 12, 2008 • Watches
2answers
Watch 3 dials inside face
so its a chrono watch i belive. well sometimes diffrent models require diffrent operations to set up the display.
Perhaps the manual can be found on the internet site of the watches brand.
Mar 17, 2008 • Watches
How do I use my watch???
I also own a PRS200. The two buttons on the right and top two subdials are for the chronometer function.
The top right button starts and stops the chronometer function: First press starts the chrono. Second press freezes/stops it, so you can record your time. Third press resets the chrono.
The bottom button is for the lap function: on the first press, it freezes the chrono in order for you to be able to record your "lap time", but keeps the chrono running in the background (you don't see this, it's the movement that does this mechanically). When you press it a second time, it jumps back to the running chrono time. You can then press it again to get another lap time, and so on...
In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
1helpful
8answers
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 • Watches
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
