Garmin nuvi 205W GPS Receiver Logo
Posted on Aug 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset home location - Garmin nuvi 205W GPS Receiver
Anonymous
Level 2:
Scholar:
  • Expert 122 Answers
  • Posted on Aug 22, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
122
Questions
0
Helped
22742
Points
397
Hello. To reset your home location do the following:
  1. On the main screen touch Tools>My Data>Set Home Location
  2. Enter address, current location, or recently found.
  3. Touch Done.
Please rate this solution if you found it helpful. Thanks, Edward.
How do I reset my I-pAD back to original factory settings
1. On the Home screen, tap "Settings" to bring up the Settings screen. 2. Tap "General"
3. And then tap "Reset". This brings up the Reset screen which will give you the following options. a. Reset All Settings - this resets all your settings back to factory default but does not erase your content data. b. Erase All Content and Settings - this resets all your settings and erase all your content data. You might want to do a sync with iTunes before performing this erase if you want to keep any music or apps that you have downloaded. c. Reset Network Settings - this deletes your Wi-Fi network settings. d. Reset Keyboard Dictionary - this clears any history in the dictionary such as the history of the keyboard suggestions that you've rejected or accepted previously. e. Reset Home Screen Layout - this simply resets your Home screen icons back to the original default layout. f. Reset Location Warnings - this erases any location preferences that was set for your apps. For example, GPS-aware apps often popup a location warning asking if you want the app to be aware of your current location. Your answers to these questions are stored by your iPad for each app. This reset will erase these answers so that the app may popup the prompt asking for your location permission again the next time you use it.
4. After selecting one of the above options, the iPad will ask for confirmation that you really want to perform the reset. If yes, confirm by tapping "Reset".
tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
I have moved, how do I reset my home address and
Either: While outside your home mark that spot your new home address.
Or: Write the address in the 'home'.
My Garmin is stuck on my last destination.
Your Garmin's Home Location has been changed.
Solution: You must reset your Home Location.
Go to Main Menu.
Select: Where to?
Select: My Locations.
Select: Set Home.
(Message: A Home Location Already Exists. Do you want to change this location?)
A. If you are at your home location, select: Yes, use my current location.
B. If you are NOT at your home location, select: Yes, enter my Address. Enter your Home address.
Press "Save".
2answers
How to I reset my home address on the take me home feature
if it is TomTom then
Tap "change Home location" button to set or change your Home location.
manual download
go to tomtom website ----> support scroll down at the right hand side click Find downloads
20/Apr/09
2answers
Locating satelites
Are you outside, exposed to the GPS signals?
If so, have you tried resetting the unit?
Remove the face cover (GENTLY pry it loose by using the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual, also available online at garmin.com /support /downloads
4helpful
Resetting Home
I'm not sure I understand the question. When you take the unit outside and turn it on, does it show you in Tampa, or Decatur? If it still shows you in Tampa check the satellite status in the tools menu, you may not be acquiring your current location.
If you're talking about the home location that is saved into your GPS as a waypoint, go into your favorite places list and delete the place named "home" then go to the location you want to save as your new home and press "where to" and then "home". Since there is no home saved, the GPS will ask if you want to save your current location as home. That should do it for you.
9helpful
7answers
How to change home map on used Garmin i3 street pilot
Hello. Had the same problem and just solved it.
Do this.
Tools -> Manage My Data -> My Locations. Position to Home and then click Manage -> Change Location ..
Cheers.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
