SOURCE: baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
SOURCE: Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
SOURCE: My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
SOURCE: baumatic bottom double oven does not work, both
Have you set the clock right, ovens wont work if clock in auto mode
regadrs
richard saupe
appliance repairman Colchester
Testimonial: "very helpful thank you"
