if the power button flashes in a pattern note down that pattern and repost the query with that included...presumable the power button light does not go out.
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
This sounds like a power supply problem, visually check the fuses and if they look ok, and you have a backgroud in electronics test to see if the set is prducing Dc voltage, you will need a multimeter and a schematic to do this with. However, if you do not have a background in electronics please take the set to a qualifide TV repair shop to have the repairs done.
Remove front speaker grill and access panel...... Turn red screen control down a little... Cause may be bad CRT.......................................T.
