Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
Check if the circulating pump is actually working - are the dishes being cleaned at all ? If not - check pump for operation and replace if faulty.
If tablets are still stuck in a compartment - replace operating mechanism for tablet drawer, or - cheaper - put tablets in with the cutlery instead.
Hello, Yes the door should be open at end of wash,either the dispenser is faulty or the p.c.b. If you dont want to go to the exspense of new dispenser etc.Try putting tablet ( I presume you are using tablets ) in the cutlery basket.If you are using powder then it will have to be repaired.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
I'm guessing from your post that your cutlery is the only thing in the dishwasher that is not getting clean, but rather with that nasty coating when you go to empty it. The reason for this phenomenon doesn't lie in a problem with the dishwasher, but rather a simple chemical and physical reaction between the dishwashing liquid (or powder or tablet), heat from the dishwasher's dryer, and the metal on that set of cutlery. The bleach from the dishwashing detergent will work very hard at getting your glasses, bowls, and everything glass and/or plastic clean and sparkling because it contains bleach in its ever-proprietary mixture of citrussy goodness. Unfortunately, metals and bleach, combined with heat are NOT a good combination! The best advice I can give you in this case (again, assuming that everything else in your dishwasher is looking fabulous and that your cutlery is the only thing that is not) is to wash your cutlery by hand with regular dish soap in the sink and do not put them in the dishwasher. Of course, it's easier to just stick all of that stuff in the dishwasher and not wash it by hand! It's why you bought a dishwasher in the first place, right? But if you want your cutlery (especially if it's GOOD cutlery) to look good and perform well, your best bet is to wash it the good ol' fashioned way...In the sink.
I hope this helps! :) Let me know if you need anything else that I can help with.
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
