If it is less than 4" you can split the difference on each side. as long as it is sealed properly the slight restriction at the coil wiil want hurtr much. As stated make sure to seal it so all the air goes though the coil.
You should prob take the coil back an get the correct size for your furnance .you can build plenum if you like lotta extra work though
