Anonymous Posted on Aug 21, 2010
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
  • Anonymous Aug 21, 2010
    solution 1 not helpful, drawer still will not open
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Aug 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
3601
Points
23
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
1helpful
The Cds get stuck in the unit; unit won't play and cd drawer won't open
HAVE YOU tried to open the tray by the pin hole on the front with a paper clip
1helpful
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
1helpful
3answers
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Disc drawer will not open
Try to hear a sound of of a running motor inside the unit. If you can hear it, the there's a broken or misplaced rubber belt. The belt drives the drawer open.
3helpful
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Cd changer drawer is stuck
GET A SCREW DRIVER ! take the lid off (make sure its not pluged in idiot!) lol!!! anyway take the lid off and take a look inside see if you can figure it out. take a look if you can see any problems jaming the door just explor it remembering where every screw goes you may by doing this may find the problem cheers
36helpful
8answers
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
