SOURCE: SATA II HDD instaling on ASUS P5LD2
Drivers will not affect whether the drive shows up in BIOS or not.
Your BIOS should have a setting under the 'Advanced' section for IDE and or SATA. Usually this needs to be set to 'Enhanced' mode or 'SATA plus PATA' Check your jumper settings-The drive should be set to 'Master' (if it even has jumpers).Check the power lead to make sure the drive spins up. Try different power lead and different SATA cable. If possible, try the drive in another machine to make sure it isn't 'Bad out of the Box'
If the drive does not show up in BIOS its a hardware issue or BIOS setting .
Once it shows up in BIOS - you'll be good to go.
SOURCE: First time connecting SATA hard drive to this motherboard - do I need special drivers?
You shouldn't need any drivers- as long as the drive shows up in BIOS and looks correct- windows will load the drivers you need to make it work. Then when it's running - load the chipset.inf driver and the LAN driver from the motherboard CD. This will get you on the internet so you can go to the ASUS site and download all the new drivers (Including the newest chipset and LAN drivers)
SOURCE: Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
SOURCE: ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the IDE slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
SOURCE: boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
