Ricoh SP C221SF Aficio Printer Logo
joao baptista Posted on Aug 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sc 400 code ricoh c221 - Ricoh SP C221SF Aficio Printer
gggg
Level 3:
  • Master 904 Answers
  • Posted on Aug 26, 2010
gggg
Master
Level 3:
Answers
904
Questions
Helped
520309
Points
1791
An sc400 error means the toner mark sensor needs to be cleaned. Cleaning this sensor is easy:
Open the top cover and remove the cyan toner cartridge. You'll see a long black lever with a sort of handle that pokes upward -- slide this lever ONCE to the left, and then it should slide back into place.
Now replace the cyan cartridge and close the cover, and your printer should be fine. (If the error doesn't clear, turn the printer off and back on and it should go away.)
Ricoh Aficio MP1600. Error SC 524?
Check out the links
Error Codes > Ricoh > MPC305SPF > Code 524
Printcopy.info https://printcopy.info > brand=Ricoh > code=524
Code: 524 ; Description: Transport motor error. The machine detects a High signal from a transport motor lock detection for 2 seconds after the transport motor ...
Missing: 1600. ‎' Show results with: 1600.
RICOH Error Code List - mtechsinfo.com
mtechsinfo.com http://www.mtechsinfo.com > files > Ricoh Erro... PDF Image compression errorHard disk drive error Aficio 551, 551P, 700, 700P SC- ... SC-524. Duplex end fence drive problem. SC-530. Bypass motor locked or fuse FU106 ...
14 pages
Error Codes > Ricoh > MPC306 > Code 524-00
Printcopy.info https://printcopy.info > brand=Ricoh > code=524-00
Code: 524-00; Description: Transport motor error The machine detects a LOCK signal from Transport motor for 2 seconds when the motor is activated. https://www.google.com/search?q=Ricoh+Aficio+MP+1600.+Error+SC+524
and finally
https://www.mtechsinfo.com/files/Ricoh%20Error%20Code%20List.pdf
Ricoh Aficio. How I clear SC390 code? Print is clear, after 10 copies SC390 code is coming. How do I solve this problem please?
Question edited tor a lot more clarity and add MAKER, but NO MODEL NUMBER! All questions need full make and model.
Ricoh Aficio 200 - Error Code: SC390
PrintCopy .info https://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ‎' Must include: cod
SOLVED: How fix sc390 cod of ricoh
Fixya https://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Error Code sc 390
Copytechnet https://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
mtechsinfo.com http://www.mtechsinfo.com > files > Ricoh Erro... PDF SC-390-2. Toner density sensor error. SC-391. Developer bias problem or FU103 on Aficio 550/650 Image storage address error. Aficio 551, 551P, 700, 700P.
14 pages
2answers
J'ai une ricoh mp c5501qu iaffiche sc819
North American website, we speak English :>)
I have a ricoh mp c5501 which displays sc819
Google Translate ici.
https://translate.google.ca/?sl=auto&tl=en&text=J%27ai%20une%20ricoh%20mp%20c5501qu%20iaffiche%20sc819&op=translate
The answer is NOT good!
AFICIO MP C551 SC 819 ( 5348 0x5554444F ) - Copytechnet
https://www.copytechnet.com > forums > 126200-aficio...
Jan. 13, 2018 - SC 819 is a fatal kernel error. Either the controller and possibly other boards were blown by the power surge or the components you replaced on ...
Ricoh Aficio 2035 SC819 Error Code - Copytechnet
Mar. 31, 2010
Error Code Ricoh MP5002 SC 819-00 - Copytechnet.com
Apr. 13, 2016
Error Code SC-819 MP 5000 - Copytechnet.com
Oct. 4, 2013
Thread: error SC 819 - Copytechnet.com
Mar. 30, 2017
More results from www.copytechnet.com
SOLVED: What is sc819 for ricoh aficio c4501 - Fixya
Sep. 1, 2019 - Yeah most likely the Hard Drive, just replace them with off the shelf ones. Could also be the dimms, controller, nvram or firmware. I would unplug the HDD first ...
SOLVED: My machine ricoh mp c2352sp displays SC 819. I
Nov. 18, 2019
SOLVED: My ricoh aficio is showing sc819 - Fixya
Jan. 24, 2018
Ricoh mp 2550 error code sc 819 how to solve this problem
Nov. 21, 2019
SOLVED: Sc819 trouble/error in ricoh aficio mp5000. any - Fixya
Jun. 2, 2011
More results from www.fixya.com
Ricoh Aficio 480W - SC819 - PrintCopy .info
https://printcopy.info > brand=Ricoh > code=SC819
Ricoh Aficio 480W · Code: SC819 · Description: Fatal kernel error. Due to a control error, a RAM overflow occurred during system processing. One of the following ...
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Ricoh sp C221SF Error code Sc 400
The board that controls it. Probably the IOB. Typically, the code is cause by a dirty ID sensor.
Ricoh SP C811DN has a sc 400 error code
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
2helpful
Sc 400 error
SC 400 is a dirty toner mark sensor. Clean with alcohol, wiping with dry cloth causes static on sensor and attracts toner.
good luck
2answers
SC 400
Hello sir; The error code you post out, it's means "transfer belt bias problem" that you have go to high voltage board ,I/O board or main board, before we go, why don't try make a reset;
1, press "clear mode" key, then enter 107 then press and hold down "clear/stop"..
2, turn power off and on.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
