Here's an article on Receiving a Paper Jam Message When Using the Front-loading Manual Feeder on a Lexmark E250d/350d/352dn/450dn. Click on this link: http://bit.ly/cWZVZo. Read thoroughly, you might get some tips on how to avert this problem in the future. If problem continues, I suggest you contact Lexmark technical support to further investigate the problem.
SOURCE: Online/error light is red
When you pull the paper out, that affect paper loading switch inside(or paper status monitering switch)
pull all the paper out, check switch inside near Loding roller
put you paper back and Put the tonner cartridge back, close the door and try agian ( i solved my problem this way)
SOURCE: hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
SOURCE: HP OfficeJet 6110 All-In-One
HP office jet 6110 all-in-one Printer will not print off internet, comes out gibberish.
There is a small, black switch under the toner cartridge that’s stuck. Remove the toner and un-stick it. It should be standing straight up before you put the cartridge back in. This is in the middle of the printer; middle of three slots.
200. 13 paper jam cartridge
