SOURCE: haier hrt02wnc compact refridgerator 1.7 cubic
I bought one of these for the basement. It states it is designed to cool 20-25 F degrees below surrounding air. This works well in the basement. Mine gets into the mid 30 f range and the basement is about 70 F. Pop and beer stay good and cold . Best if you pre cool before putting it in the frig. This frig is a thermal electric unit and has no compressor or refrigerant, Will not work well in a non air cond area. It is make like the plug in cooler you can plug in to you car cig lighter. This doe's work well for what I am using it for but I wouldn't try to keep meat in it just beverages and such.
SOURCE: I have a mini fridge
Hi ejb9,
I'm Harvey the Master Plumber.
Your question is: You have a mini fridge at school, a small Haier. Your fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
May be low on freon or cloged expantion valve. You're going to need a certified tech to check and repair. Maybe it's time to look at the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
